- 106
If you're looking to implement solar panels on your property or business, you are in luck, as the permitting process may now be faster then ever with AI. California is implementing a AI-powered permitting process that helps expedite solar deployments. The tech helps to automate regulatory checks, which can lead to faster approvals and more efficient installations.
The intended purpose of this new permitting process, is to enhance efficiency of the system and to simplify the process for the public. As well, this will go a long way in supporting California's clean energy goals by facilitating a quicker transition for sustainable energy practices and the states renewable energy objectives.
If you happen to live in California and want more detailed information on this, you can read the full article on Planetizen.
- California, United States
