- Apr 16, 2023
- 746
- 132
In Miami they're apparently having problems with buildings collapsing unpredictably, which is obviously not at all ideal. They discuss the issue in this article, including describing a recent incident where a building at a construction site in the Brickell neighborhood partially collapsed and narrowly missed hitting pedestrians and drivers. The news outlet mentions several other building collapses in recent memory, including the tragic surfside condo collapse that happened a couple years ago. Miami's building department is in the process of developing more restrictive procedures for permitting demolition, including potentially not allowing work highly populated areas and making sure that larger areas of property and roadways are closed off before work begins.
There's sort of a cognitive dissonance thinking about Miami's building stock being this vulnerable to collapse, especially when you consider the City's stringent requirements under the statewide Florida Building Code (FBC). As described here, Miami is located in a "High-Velocity Hurricane Zone, where local code requires that a building’s entire envelope (including windows, doors, and eaves) incorporates lab-tested, wind-resistant design." I understand that implementation of the FBC only started in the early 2000s, which I'm sure explains why structural integrity remains an issue for many of the city's buildings. Hopefully the City starts doing more to mitigate collapse risk not just through improved permit processes but also through improved inspection coverage for the city's existing building stock.
- Miami, Florida, United States
