Is my zoning variance up to par?
Davenport
I applied for a permit to build a garage, but my application was denied. Unfortunately, the garage is too tall and wide to fit within the zoning limits. I can't make it any shorter or narrower, or I won't be able to store my boat inside the structure. A workaround is to get a variance. So far, I've obtained letters from my neighbors stating that they're okay with the structure. I've explained my compelling reason for needing the variance. I've also included detailed plans from the builder. I'm set to go before the planning committee in January, hopefully. I really need to get this thing approved. Is there anything else that I should do to help my chances?
If you live in a HOA community, or if there's another neighborhood organization that creates and enforces rules, you will likely need their permission to build the garage before your variance is granted. If this applies to you, I'd attach the neighborhood rules that show you don't need their permission, or I'd go ahead and get their signatures in agreement to your variance application.
It's frustrating to have a project curtailed like this. I wish you luck and hope that you'll prevail.
From what I've heard, we need to show that the proposed variance is not caused by what we did. The variance should not alter the environment's characteristics or create further issues. The appeal sounds complicated, but it sounds like you're well prepared. Good luck!
Luckily, I can easily meet this requirement. I'm hopeful that it'll be approved.
Kayward, I don't have a HOA or similar governing body to worry about. I'm grateful for that, because I've heard it's much more difficult to receive a variance in that instance.
