Nomad
- Aug 26, 2023
- 537
- 93
Marathon has enforced the latest Florida Building Code Eighth Edition. If you are in the process of getting building permits you will have to carry the FBC23 stamp for initial approval. While submitting your permit applications, you will have to thoroughly outline the proposed work and provide comprehensive plans. For example, if you are constructing pools, tiki huts, or accessory structures, you will have to provide a foundation survey pinpointing the exact work location. If you want to make any modifications, you will have to provide a completed revision application, with required engineered plans. To make it more complex, permits require approval from Florida Commerce.
You can read more about this here.
- Marathon, Florida, United States
