GPT Minnesota Building Codes
Have feedback on the GPT's performance? Please discuss in the thread below.
The Minnesota Building Codes GPT incorporates the following:
  • 2012 International Green Construction Code (IGCC)
  • 2012 International Property Maintenance Code (IPMC)
  • 2020 Illustrated Field Guide to the Minnesota Residential Code
  • 2020 Minnesota Accessibility Code
  • 2020 Minnesota Building Code
  • 2020 Minnesota Conservation Code for Existing Buildings
  • 2020 Minnesota Guide to the State Building Code
  • 2020 Minnesota Mechanical and Fuel Gas Code with ANSI/ ASHRAE Standard 62.2-2016 and ANSI/ ASHRAE Standard 154-2016
  • 2020 Minnesota Residential Code
  • 2020 Minnesota State Fire Code
  • 2023 National Electrical Code (NFPA-70)
  • 2024 Minnesota Energy Code with ANSI/ASHRAE/IES Standard 90.1-2019
Have additional documents to add? Please reply below. Any files or webpages you'd like incorporated into the GPT can be included as attachments to your posts.
Minnesota, United States
This query is incorrect: "According to the 2020 Minnesota Residential Code, the minimum riser height allowed is 4 inches (102 mm). This is specified in the context of stair riser heights, which must be between 4 inches (102 mm) minimum and 7 inches (178 mm) maximum ."
There is no minimum requirement in Section R311.7.5.1 of the 2020 Minnesota Residential Code.
Thanks for the feedback! It appears the GPT was confused by your reference to the MN Residential Code as part of your question.
You asked: "In MN Residential code. What are the minimum riser heights allowed?"
If you instead simply ask "What are the minimum riser heights allowed?", here's the response you'll receive:
The minimum riser heights allowed vary depending on the specific code and context:
  1. General Stairs (2020 Minnesota Building Code, Chapter 10 - Means of Egress):
    • Minimum riser height: 4 inches (102 mm).
  2. Accessible Stairs (2020 Minnesota Accessibility Code, Chapter 5 - General Site and Building Elements):
    • Minimum riser height: 4 inches (100 mm).
  3. Residential Stairs (2020 Minnesota Residential Code, Chapter 3 - Building Planning):
    • Minimum riser height: Not explicitly stated, but the riser height must be uniform and comply with the maximum height of 7 3/4 inches (196 mm).
  4. Fire Escape Stairs (2020 Minnesota State Fire Code, Chapter 11 - Construction Requirements for Existing Buildings):
    • Minimum riser height: Not explicitly stated, but the maximum height is 9 inches for stairs serving more than 10 occupants and 12 inches for stairs serving 10 or fewer occupants.
It looks like the GPT provided the correct answer - 4 inches, based on Building Code and Accessibility Code - but deferred to you in attributing the requirement to the Residential Code.
I apologize for the unclear answer you received. For future queries, I suggest omitting any reference to specific codebooks.
If you have further feedback, please don't hesitate to let me know!
