Nomad
- Aug 26, 2023
- 537
- 93
I found an interesting question on Reddit that I believe would also be an interesting topic for discussion here. A homeowner in NYC is having trouble with their electricity, so they called a top-rated electrician from Angie's List. The electrician said that the problem was with the old 90-amp electrical panel and it needs to be upgraded to solve the problem. According to the electrician, no permits are needed because it is just a "home improvement." and not a full upgrade to a 200-amp panel. However, the homeowner is little cautious so they actually want to now if permits are not needed for home improvements. What do you all think?
If you want, you can check this Reddit's original post.
- New York, New York, United States
