- Apr 16, 2023
- 718
- 125
Occasionally someone purchases a home only to discover that permits weren't obtained for some of the home's past renovations. The homeowner may decide to fix the unpermitted work to meet code standards but may be uncertain how to engage permitting authorities on the issue. To understand how different jurisdictions handle this situation, and what the consequences might be for affected homeowners, I emailed the following question to 15 different building departments:
"In cases where a homeowner has purchased a property with previously unpermitted renovations and has since updated it to current code standards, what are the typical procedures for obtaining retroactive permits or inspections? Additionally, what are the potential consequences or requirements a homeowner might face in such a situation?"
Here are some key takeaways based on the responses I received:
Atlanta, GA - Office Of Buildings (1/4/24):
Bend, OR - Community and Economic Development Department (1/4/24):
Cedar Key, FL - Building and Planning Department (1/16/24):
Charleston, WV - Building Commission (1/8/24):
Henderson, NV - Development Services Center (1/8/24):
Islip, NY - Department of Planning & Development (1/9/24):
Juneau, AK - Community Development Department (1/23/24):
Meridian, ID - Community Development Department (1/5/24):
Miami, FL - Building Services (1/4/24):
Morgantown, WV - Code Enforcement (1/8/24):
Portland, ME - Permitting and Inspections (1/4/24):
Sacramento, CA - Community Development Department (1/8/24):
Tacoma, WA - Planning & Development Services (1/4/24):
Washoe County, NV - Planning, Building, and Engineering Division (1/8/24):
Worcester, MA - Inspectional Services Department (1/8/24):
- It's possible that the unpermitted work is actually exempt from needing a permit. Before inquiring with the building department, you might consider researching whether there's a code exemption that covers the unpermitted work.
- Building departments will typically evaluate unpermitted improvements as if they're proposed work that hasn't been completed yet. As with a typical application, you may be required to enlist an architect or contractor to prepare existing and proposed plans that clearly show every detail of the work that was completed.
- In some jurisdictions, you'll need to pay higher fees (e.g., double that standard application fee) as part of the after-the-fact permit process. Some jurisdictions don't charge any penalty fee (e.g., Henderson, NV).
- The building code in effect at the time of the unpermitted work may differ from the code in effect today. Work that appears to require a permit might not actually need one, depending on when it was completed.
In cases where unpermitted work was done, the current homeowner(s) can still apply for a permit. Please note that the language of the permit assumes the work is yet to be done, i.e. existing plans showing the state of the property/structure prior to the unpermitted work and proposed plans showing the present day state plus any additional work you want to add to the permit.
Consequences would vary from situation to situation, but could include double permit fees or court appearances, should the unpermitted work be discovered.
In the best scenario, there will be building/floor plans that we can retroactively create an application as if starting from the beginning, have it reviewed, and then ultimately inspected.
If that’s not possible, we can still have you initiate a new application, sketch out all the work that is/was known to have been done, and then if we can retroactively inspect it we will.
The risks to the homeowner can be life/safety issues for unpermitted work and the issue of selling their home down the road with unpermitted work.
What are the typical procedures for obtaining retroactive permits or inspections? All the same steps must be taken as if the work had not been done. Plans and a contractor are required. Permit application must be made. Permit fees paid and Application must be approved. All required inspections must pass.
Additionally, what are the potential consequences or requirements a homeowner might face in such a situation? Unknown. There are many variables. The Building department will not address the work unless it is currently in progress. Of course, unpermitted work can present dangerous situations. The homeowner will not be penalized for unpermitted work done by previous owners. The work must be uncovered for inspection.
If no permits were obtained during the remodel, then there is no way to know if it is to current code. There would be no way to obtain and permit or inspections for past construction.
If a new homeowner has issues with the remodel/construction, It would become a civil matter between the new homeowner and the previous homeowner.
The customer would apply for the permit just as if they had not already done the work. They can write retroactive in the scope of work just to let us know, but we will look at the plans as if the work had not been done. The customer will need to let us know everything that was done with drawings of the before and after. If the scope of work is a remodel, then they will need to tell us the square footage of all the work done broken down by trade (i.e. architectural 50 sq ft, electrical 20 sq ft, etc.).
We do not add late fees or violation fees for those permits; they would just pay the typical permit fees. If the work that has already been completed is not up to code, the inspector will make them bring it up to code before signing off on the permit.
Every case is different, it all depends on what kind of work has been done and how long ago the work was been done for.
All new work (less than 4 years old) have to come in under a building permit application, and follow the requirements for whatever the scope of work is.
Any work 4 or more years old a compliance permit application can be use.
Inspections can be scheduled after permit has been issued.
Typically we act as if the unpermitted improvements have not been done yet, we perform a courtesy inspection of the unpermitted improvements and if they are acceptable we issue an “after the fact” permit, approve the work, and charge the appropriate fees. We don’t normally issue a fine if the homeowner comes to us. We do issue a fine if it’s an investigation situation.
If the homeowner wants it inspected, they will need to pull a permit. In order for certain things to be inspected, i.e. if a load bearing wall needs to be exposed, the present sheet rock may need to be removed. It all depends on how extensive the renovation is. Also if any trade, i.e. elec, etc., has been done, certain walls or portion of walls may need to be removed. The homeowner can consult with each of the supervisors to see if a wall will need to be removed.
In most cases, double fees are applied, due to work being done without a permit. Again, the homeowner will be consulting with inspectors, and if extenuating circumstances apply, they may not double the fee. It all depends on the circumstances.
In the case of unpermitted renovations, you must have to find an Engineering or architect who sign a letter (as Built) and plans where he approves according of Constructions Code (Florida 2023, 8th Edition) the renovations, and find a Contractor, Fill it out the application online specifying that it will be a Legalization.
You will need to submit a building permits for renovations that was done or submit for any projects that needed to be completed
Visit
www.morgantownwv.gov
department
code enforcement
step by step process on line permits
let me know if you have any questions it would be best to call the office
You will need to apply for an "After the Fact" permit and you would apply just like a regular permit. In the description you will want to put "after the fact" and then a description of the work you had done and are applying for. Then once the permits have been issued reach out to schedule the inspections.
The responding staff member also shared their "Planning Exemption Form - Express" form, which I've attached to this post. If unpermitted work meets one of the categories listed on the form, the homeowner can simply mark the exemption category and sign the form, thereby self-certifying that the work doesn't require a permit.I read your inquiry below. To permit preexisting work, the process is the same as permitting work that you would intend on doing. There are a couple aspects that may be difficult when the work is already completed but usually an architect or contractor could verify the work that was completed so you would detail it in the job description of the application.
If it requires plans to be reviewed, you will need to draft plans to cover the scope of work and submit those plans through the online portal. If there happens to be a housing case for this project from Code Enforcement or the Dangerous Housing and Building department, you will need to include the case in formation in the work description.
The case notes would also be a good indicator on the work that would need to be completed.
Lastly if you decide that permitting this project is too complicated or expensive and want to change it back, it would be a minor permit with the work description of changing it back to preexisting conditions.
You can apply for the correct permit type and include “retroactive permit” in the description. Please note that any work that is currently not up to code should not be remedied without getting the permit BEFORE completing the work. If the unpermitted work has created a violation record, there will be an additional fee assessed at the time of permit issuance.
Like Sacramento, the code enforcement officer who replied to my email also provided information on the County's building permits exemptions. I attached the document they provided to this post.I am the Code Enforcement Officer that investigates the building and engineering complaints. The first question that would need to be answered is what the “renovations” entailed and the scope of the work that was done? When were the renovations completed, as this may change the building code that was applicable at the time the work was done? I have attached a handout of items that do NOT need a permit. Many times kitchen, bathroom, and basic “remodels” of flooring, drywall repair, and other interior cosmetic work would not need a permit unless there are changes to the structural members, plumbing, electrical or additions. To provide answers to your questions or give direction for compliance, I would need to know if the renovations needed permitting. If the renovations needed permitting, how extensive was the work? Will the permit requiring architectural plans, engineer certification, or other involvement from a design professional? Is it, or was it, a rental property? This would require a licensed contractor as the owner/builder would not be able to perform the work. There are so many variables it is difficult to provide you definitive answers for “consequences of requirements” for the homeowner. My contact information is listed below if you need further assistance.
They can reapply for a permit. I don’t know what the consequences would be truthfully unless they go to sell it and the new owner questions permits.
- United States
