Nomad
- Aug 26, 2023
- 537
- 93
The specific requirements for permits In the United States vary from one state to another, or even county to county. Therefore, if you are making some changes in your home, make sure to check with your local building department or permitting authority. However, for a quick guide, here are home improvements that usually do not require permits:
Cosmetic Changes: Minor cosmetic improvements such as painting, wallpapering, and installing new flooring do not require permits.
Cabinetry Installation: If you want to install new kitchen or bathroom cabinets, or replace kitchen or bathroom countertops, without making any structural changes to plumbing or electrical systems, you don't need permits.
Roof Repairs: You need permits for structural changes in the roof but do not need permits for small roof repairs such as replacing shingles or repairing small sections of the roof.
Minor Plumbing/Electrical Repairs: Small plumbing repairs such as fixing leaks, replacing faucets, or installing new fixtures, or minor electrical work such as replacing light fixtures, switches, or outlets may not require permits.
Window and Door Replacement: If you are replacing doors and windows of the same size, you do not need permits however, altering the size or location often requires permits.
Landscaping: You do not have to seek permits for landscaping, planting trees or shrubs, and installing walkways or patios. However, you need permits for major grading or drainage changes.
Temporary Structures: Setting up temporary structures like small sheds, playhouses, etc. also do not require permits in some areas.
- United States
